I am trying fit my turbos in the 200sx conversion, I need to rotate the outlet housing to another position. I have loosened the 4 bolts that hold the 2 'C' plates on the exhaust housing but it still won't turn. I'm sure that's all that needs to be undones for it to turn? Also there is now oil in the exhaust section so the seal must have been broken?
I've given it a few taps with a hammer but no joy, any ideas???
Are these used tubs?-if so they will be stuck tight.Take the bolts/plates off completely and keep tapping and spraying until it parts.
Clean the surfaces and re-fit,should then turn where you need em'.
