Lights Electrical hiccup. Confused now!
Hi All.
So after installing the new faces on my clocks(from ZX-TT) I re-built the clocks, surrounding area and switches. Put the negative lead back on the battery and got a 'bong-bong'.. I had accidently thumbed the fog light switch and the door was open.. no drama there. If anything - that was a good sign.
so I need power for these new faces and got it from the power to the lights splicing into the wires behind switch gear. No drama here either. It worked well.. I had Bright green faces or Bright Blue when I turned the lights on.. had a bit of a play..:biggrin: very happy..
:blink:Then something changed. Minutes later.
I now have full-beam and only full-beam as a headlight option. No 'bong' when the door is open, and the fog light tell on the dash is permanently showing even tho the small tell on the front fog switch is not. I also now have no power from the wires like I once had.
Fuses passenger engine bay OK side. Fuses in the small box on other side of engine bay seem OK.
What do you reckon changed? :huh:
I have been at it some more.. and yes have found the fuses in the footwell.. but alas i have not bought a car that comes with a fuses box cover with helpful graphical representation of the said part.... it could be any of them.. and its dark down there.. hahahahaha.. and the electric chair keeps trying to trap me, crushing me into the footwell cos I'm leant over the controls.
I'm handling the chair business quite well tho. sence of humour ago-go!
many many thx. :thumbup1:
I'm giving the 'not having a cover' 4 marks out of 10 for helpfulnes. It should score zero, but I never would have seen the fuses had it been in place plus I wouldn't have be reminded how good people can be when you are in need.
Glad you like them :) your back brakes Are in the garage :)
