June 23, 201213 yr Just wondering if anyone has fit another car calipers that will fit the zed with mods.???? Ive got the skylines bremos off 350z is there any other which i can get on my zed ??ty jay
June 23, 201213 yr The Brembo's from the Skyline GTR and 350z are the only bolt on Direct OEM Brake upgrade available. However, pretty much any Manufacturer brake setup can be made to fit with a suitable custom bracket manufactured to fit. The only issue to be aware off is Disc fitment, since not all maufactures use the same PCD fitment, you may not be able to use the Discs that come with the calipers, so have to source seperate discs, and have the brackets made to not only fit the Z32 hub, but also for new disc offset. A few members (here or on other Z sites) have fitted Calipers from other models such as Jagauar, Porsche ..etc The Mitsubishi Evo 6-9 Brembo's are larger than the Skyline/350z Brembo's and often available very cheap, and a couple of members here have done the upgrade with custom brackets (and may have the drawings available for them already). In terms of Aftermarket setups you have bolt-on options from : AP Racing Brembo Stoptech Rotora K-sport D2 Wilwood ..and plenty others. The K-Sport/D2 (same manufacturer, different name) are the Cheapest aftermarket options, although not nearly as cheap as they used to be when they first came out. Any Brake upgrade that is advertised to fit the Skyline, 200sx, 350z will also fit the 300zx. They all have the same Front fitment, and with the exception of the 350z the rear fitment is the same too. Edited June 23, 201213 yr by Yowser
June 23, 201213 yr what part is needed for the 350z fronts?ty jay 350z front is direct bolt on. So you just need Calipers, Pads and Discs. The rears are not. Edited June 23, 201213 yr by Yowser
bremos off 350z
