How many different Plenums are there?
As the title suggests, does one type of plenum fit all models? jap, uk, TT, Na, Manual, Auto, LWB, SWB?
Plenums are all the same, just the balance bar that differs between tt and na.
there is a slight differents in the plenums ... nothing major
its the bolt patten and flange on the EGR outlets
i got 2 in my garage that are different ..
So could this prevent it from been fitted? or is there a quick way around it?
yeah it does stop it a little as you can not bolt up one of the EGR pipes ...
when i cam across this all i did was got my monkey wrench and twisted it until it aligned up correctly
If I'm honest I'd be lieing if i said I knew what an EGR was. but basically your saying its not impossible to make it fit?
nope not impossible just a but of a bugger if u happen to get one ..
on the plenum there is 2 holes under it where the Pipes that run each side of the engine around the back
its just the flange on the end of the pipe that bolts to the plenum that is at a different direction
all you need to do is use to force and twist/rotate it about half inch so the bolt holes align up
Mark
Mark
Excellent Cheers Mark.
