interior lights
hi
none of the cabin interiors have ever worked...ive checked fuses, and bulbs, and can't get them to work.
any ideas or suggestions on how to deal with this
cheers
stewart
nice to see the forum has some helpfull members
No Idea Im afraid. However the forum does have many helpful members. I think considering those are your only two posts you have made on the forum, I think your being a little hasty to judge. Not many people been around the past few days, as this is the UK forums, and we have had an extended Bank holiday weekend due to the Jubilee.
Im sure when someone who does know the answer comes along, they will post. As it will need a definitive answer, no one is going to post if they dont know.
I also assume you are here as your national forum doesnt have the answer? Please give people a chance and they will answer if they know the answer.
Well said Ryan, exactly my thoughts.
I read this thread when posted and as was stated fuses and bulbs had been checked I had nothing to add :no:
In post 2 a simple bump would of sufficed or a quote 'guys can you help me pls' - what you put just rubs people up the wrong way :huh:
I thought Gaz in post 3 was very polite considering.
ok, thanks fellas...chill out
i joined to access a tech article on AAC\ /idle....and thought id try my luck with the electrics problem
thanks for your help, and i did like the link 'gary wilson' posted, ill follow some of it up
cheers
run a meter across the bulb holders and with the doors open see if you have volts if not do the same across your doors switches to see if there switching ok ,,if all fuses are ok and bulbs changed then then its just supply last step is the wires
Hi mate, have you tried checking the continuity of the wires with a multimeter?, could be a break in the wire somewhere.could also be a dodgy switch on the door pillar not working which is causing the interior light not to work.dont know how much rain you get in sydney but it could be the dreaded targa drain leak onto the electrics causing you problems.......just a few thought bud :)
Electrical problems are difficult to diagnose without various tests. It's a delicate issue and if people aren't experts, then it's more worthwhile to visit an expert.
Always worthwhile having a look yourself first though as it could be something really simple.
cheers
LOL.. by the way, welcome to the forum Stewart, albeit your first contact a touch abrasive....
I too am an Aussie, but have been in the UK for 18 years now... we have a few members on here form Oz, NZ and a number of other countries all over this little planet...
please don't think yours is the first or only sarcastic post.. we do get them from time to time, not always for the same reason.... but who is perfect anyway!?!?!
I hope that you continue to visits us and we can be of help :)
cheers,
Gerry.
