I've got a Saxo (dont ask) and I just wanted to change the pads so went to get the wheels off and they have some starange bolts that you need to stick a hex key inside and undo. Whoever had done them before had massively overtightened them and broke 3 of them! The walls have all snapped meaning there is nothing for the hex key to grab and theres also nothing I can bang a socket over!
I'm not fussed about using the hub again as they are only £10 each from the scrapyard so would drilling them out be a bit of a ball ache?
Cheers in advance for your help and advice, positive rep all round :thumbup1:
You have nothing to loose buy trying, start with a small drill and work your way up, use good quality drills and some oil and it should be no problem.
Paul
Cheers for the advice mate, went out and brought some cutting fluid. Took me about an hour per bolt but got there thanks :).
