just got the Z though its MOT and surprisingly it passed :clown:
The MOT man did say there's slight play in the rear wheels but wasn’t sure its suppose to be like because of the HICAS. So is there suppose to be slight play in the rear wheels?
no shouldn't be any play as far as i'm aware it was pointed out on my white zed a couple of years ago, could be arms or hicas ball joints
As above, Should be no play.
I would start with the inner track rod arms and ball joints first, more likely to be the first thing to go. (easier as well)
Failing that I would then change the outer ball joints that are pressed into the hub.
Worth doing all at the same time if you ask me. just done mine. massive difference when driving.
