issues with consult
OK,
Kind of stumped now… have issues with my consult connector (well I thought that’s what it was).
Changed the connector over and extended the cable, checked all connections and all are fine, still won’t work. Also swapped the ECU.
Checked the wiring diagram and (most) wires go back to the ECU (F1) via connector M64 / F2, the Green wire goes to M17 (combination meter) and M11 then fuse…. Don’t think I checked M17…
I’ve checked the rest of these and all looks OK, I can’t see anything else I should be checking ….. could the connector to the dash clocks cause this if they have problems?
http://www.karljapetre.com/z/ecu/eccs-color.gif
I know my laptop and consult works because I connected to another car and it’s fine… I also tried another laptop with consult (that works on other cars) and it won’t work on mine.
I used a multimeter and get readings back from both diagnostic communications wires (port 21 & 22) but nothing from the diagnostic power 31???? Not even straight off the ecu connector….
Cheers…
i have the same issue, had brought version of conzults, had to extend the box from the port to the rear of the car, now wont work so have to use the free version just to get the visual display of parameters, but if i want to actually test or check anything i have to use ODB scantech Nissan.
Heard it has something to do with conzults thinking you have a illegal copy so refuses to connect as it wont connect with a ebay conzults box either for some strange reason. i think it has something to do with extending the cable in my case. though my laptop is fecked now so cant check.
Edited by vodkashots
cheers...
Ah.... yes, same as me.... you have complicated matter as as well with an extension... i have however checked the extension and it's got good connections...
but my free version of conzult just keeps saying "can't connect to ECCS" and there isn't a voltage /signal from the orange power wire from the ecu..
