My latest SWB TT Z32 build
I thought it was about time that I started a build thread for my SWB TT manual, as my old LWB TT manual build was a big fat failure (read: ended up getting cut up into bits on my driveway and carted off to the scrappy in the back of a pikey's transit van!!)
I figured that this time, rather than give a step by step commentary of its progress (which can be depressing when progress comes crashing to a halt) this time I decide that I'd build it first and when it was pretty much ready to hit the track, only then would I write it all up afterwards..
Here's the old girl as of yesterday afternoon, about 99% ready to rock:
(big thanks have to go to 'Monster' and Whifbitz for some really nice parts at very generously low prices)
*I'm currently running a tidy VG30DETT that had been tinkered with in Japan, I'll run this until I kill it this Summer by which time I should have finished re-building the forged lump (below). The bottom end is finished, I just need some new cometic gaskets....joy)
(Engine)
VG30DETT (bored/honed ’20 thou)
Carillo ‘H’ beam rods
Arias oversized pistons
ARP bolts
Cometic gaskets *
Nismo 740cc injectors
300 degree fuel rails
SE ported and polished heads
SE cams/valves
AMS pulleys
ACL bearings
Polished crank
AMS manifiolds + gaskets
HKS turbo elbows
Garrett GT675 RS turbos
Polished water pipes
New OEM water pump/oil pump
EGR/PCV delete
NGK spark plugs
Unorthodox racing lightweight pulleys
Blitz custom exhaust (titanium wrapped)
Greddy 3 row front mount intercooler
ARC GTR oil cooler + braided hoses (front mounted)
Koyorad radiator
Nismo rad cap
CZP radiator hardpipe kit
ARC bov's
Greddy expansion tank
Greddy oil catch tank
Blitz oil filler cap
Greddy sandwich plate
Samco intercooler pipes/radiator hoses/vacuum hoses/intercooler couplers
SFS water/heating pipes
HKS twin induction kit/Samco elbows
AEM EMS
AEM 3.5 bar MAP sensor
LED headlight conversion
Bosch 044 fuel pump
Accusump
Cusco brake stopper
(Transmission)
Carbonetic triple plate clutch + flywheel
Carbon one piece prop
Re-built OEM gearbox
(Steering/Suspension)
Tein Type Flex coilovers
Tein EDFC
Driftworks front upper camber arms
Driftworks front lower arms
Driftworks Geomaster tension rods
Driftworks polybushes
Tein inner tie rods
SPL version 5 outer tie rods
SPL front drop links
Stillen front ARB
Driftworks HICAS replacement kit
Driftworks rear upper camber arms
Driftworks rear lower camber arms
Driftworks tension arms
CZP rear drop links
Stillen rear ARB
Ksport 8 pot brakes (356mm discs) front + braided hoses/Yellow Stuff pads
Ksport 6 pot brakes (356mm discs) rear + braided hoses/Yellow Stuff pads
(Exterior)
Satin black paintjob
Stillen GT-Z front bumper (modified)
Border vented fenders
Carbon fibre vented bonnet
Carbon fibre vented front panel
Carbon fibre fuel door
Carbon fibre aeriel delete plate
Carbon fibre cannards (front bumper)
Adjustable bumper support bars
Carbon fibre ‘Origin’ GT wing (formerly fitted to the Driftworks S15)
Aero-catches (rear hatch)
Stainless bonnet pins (bonnet)
Border JDM wing mirrors
CMS skirts
Flared rear arches
’99 spec rear lights
HID headlights
Scroth tow loop (FIA approved)
Red enamelled rear tow loops
17” Riverside deep dish split rims (10j & 9j) ET -7 (only set this side of Mars!)
(Interior)
Sparco Kevlar Pro 2000 drivers seat
OMP seat rails
Sparco Kevlar rally seat
Bride seat rails
Takata 6 point harnesses
ASD hydraulic handbrake + Willwood brake cylinder/pass through kit
Driftworks hydraulic brake lines
Personal steering wheel (Ltd edition OZ Racing)
Nismo GT gearknob
Autopower/Pegasus Auto roll cage (SCCA/FIA approved 1.75 inch x 0.120" DOM)
Carbing rear strut brace
HKS Oil temp/Oil pressure/Water temp gauges
Greddy 60mm (pillar mount) boost gauge
APEXi multichecker
Tein EDFC controller
Greddy Spec ‘S’ boost controller
Blitz AF meter
Lifeline 2ltr on board fire extinguisher system
Electric cut-off switch
there are probably a few bits that I've missed off the list, but it's all going in the right direction this time at least
Simon at SJS Design is currently working on some custom decals
more pics to follow shortly...
Edited by jap.slapper
  • Replies 55
  • Views 6.2k
You've got some serious kit there mate and it looks mean as fook. lol What power are you aiming for?
ignore steamy, swap it for mine, not sure you are going in the right direction with it :lol:
I'd like a reliable 500-550, depending on how it go's
Deal :tongue_smilie:
I've still got a box of bits here for you mate, they're in the garage out of anybody's way so can stay there until you need them, no hurry bud
sweet be over tonight to swap :lol:
thanks with the parts bud, trying to sort things out so i can get all my lovelys here ready for the car to come of the road for repairs. will let you know in the next 3 weeks about arranging courier
behave you :slap:
Nice mate, it's going to be a top one when you finish her :tongue_smilie:
ASD hydro imported from the US, I opted for this as it's the same one that 'D-Mac' (Darren Mcnamarra) is running in Formula Drift
The clutch swap was long over due thanks to a few motorway/duel carriageway encounters that effectively killed my old one
Nice work Pez!!
Should be a nice track weapon. Glad to have contributed! ;-)
Andy
sorry mate, in the end I didn't think that pink fluffy dice went with satin black....but thanks anyway :tongue_smilie:
no that Greddy fmic is a really good fit, many thanks bud :thumbup1:
Like it.
Reckon your hydro is too far away tho and you'll just end up bending it 'cos of the angle. It's always easier pulling it towards your body rather than inline with the cars x axis. Mine goes in a similiar place but on drivers side of the tunnel. It's not as big as yours ;P and sits nicely between gearstick and steering wheel for easy 'panic wanding'! lol
ooo, also have you got any lock mods? SWB is pretty snappy and Z standard lock is sooo poo I'd recommend at least some lock spacers (my current setup), offset rack spacers are better (Cowpattmatt is running these on his Z in the BDC at the mo (although can damage rack end seals). Front subframe mods to move the whole rack forward and hub mods would be best (I'll get round to this eventually!)
Well that is a million miles away from what Gonzo handed over to you what seems like just a few months back! If I'm honest, I think it's a bit of a shame you couldn't have found a less-nice example to abuse on the track, but if you're going to invest all that time and effort, it's logical you want to start from a sound original motor. Certainly has plenty of attitude - I really hope it's still registered for the road too? I think anyone seeing that much intercooler closing in on their rear-view mirror would know to get the fook out the way! Not that you would be hammering it, obviously!
Good work fella, hope to see it in action sometime (awesome standby engine spec too - you must have some very good friends, or very deep pockets!)
I'm running spacers on the rack at the mo' and opted for DW geomaster arms as the standard straight DW arms were catching on full lock. I'll see how I get on with this and will adjust accordingly
Christ that's one evil looking zed, those carbonetic clutches are the nuts, the only clutch I've ever bought to come with instructions on how to launch the car!!! Lol
Cheers bud,
and Yeah I know what you mean mate about it being a shame, but after the last project I decided that I wanted a sound base to work from and credit to Marty and the previous owners, this shortie' is immaculate.
I suspect that this engine won't last too long, especially in this heat, so I'd best get cracking and finish the other one off quick
as for deep pockets and friends :biggrin: I have some good friends who have helped me and my business grow in a very short period of time, and their garages really are something to behold.
I'll try to do this build justice and get some seat time in sooner rather than later
can i rob the pic please :)
Fill your boots mate, though this was taken on my Blackberry so I'll try to get some better ones as soon as I've fitted the washer jets
Nice one cheers mate. If you could get a side on view that would be great!!!
Rgr
