I don't want to fit a a commercially available delimiter/speedo conversion as I don't believe the signal 'chopping' approach is the corect way to do it.
Has anyone investigated the possibilities of doing this conversion as I would suggest.
Firstly what I would like to do is remove the speed limiter in the ECU to remove the top speed restriction, in order to do this I need to know the location in the ECU chip that this data is held or if someone can supply a 'deristricted' chip I may be able to locate and modify the information.
Secondly it should be possible to modify a KMH the speedo to read in MPH by adjustment of the output voltage.(i.e resistor change,I think I saw a similiar mod for Supra's.) Again if I could obtin an MPH speedo and compare it to an KPH it may be possible to obtian the info to carry out the conversion.
Anyone tried this before or have any info.
