I got a massive task.
As somebody know I am trying to tune my zed and i got some problems.
I installed 555cc injectors and i got chip to run that fuel from AndyP
But problem is that i spend 2 days to try fix over fueling and it was unsuccessful.
Its over fueling badly cylinder 1 and 4 doesn work but tasted for small runs and its run good on higher revs than i put it foot down. Its spins wheels and its runs fast. But on 1-3 k revs two or one cylinders doesn work.
Please give me advice why is over fueling ? Chip is made to work for 555cc injectors but what is wrong?
May be somebody have 555cc injectors and can tell whats wrong with car?
i don't run these injectors yet, but couple of thoughts,
is the chip defiantly right? sounds like it might not be.
what turbos you running?
are you running a dual intake? can the engine get enough air to support the larger injectors?
I am not sure it can be chip fail. Can stock ecu back to factory settings even than chip is in?
I am running pe1420 turbo
Got hks dual air intake with hks filters. I think i got definetaly enought air. Its 100% over fueling but why?
what injectors are they and how old ?
Its venom light blue 555cc injectors, i bought them from club member he said its nearly brand new.
Can failed injectors give to much fuel then running lower revs?
yes .... and those injectors are a little sketchy on the reliability
and to what i have read that is one of the problems ... over fueling
Not a great new but ... So how i can test if that is injectors problem? Please help.
you can not .. they need to come out and be sent off ... to some one that can run Flow/Calibration tests
