Why Should I get Kit Cambers on Z?
In the process of installing the BC Coilovers suspension..I been adviced about getting the kit cambers front/rear on the Z; question is; I barely drive the Z that often; I mean weekend drive..some long trip once &while...I mean is it nessesarily recommended to install kit cambers with the BC Coilovers? tires would waste so soon?
Really depends how much you plan to drop the ride height once the coilovers are fitted mate, more you drop the more your camber will be out
I'm sure the kit to adjust the camber is comparatively cheap to that....
It would not only affect your Tyre wear but also your handling..... i suppose if you only lowered it at the shows and then put it back up for the drive it wouldn't matter at all.
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=300zx+camber&_sacat=See-All-Categories
prices aren't too bad, however I don't know how good this stuff is... :)
mine is a daily drive and I've got a set of these on the front... seems to be OK..
http://www.ebay.co.uk/itm/Nissan-R32-GTS-GTR-Z32-300ZX-Front-Upper-Camber-Arm-x2-/170574634523?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27b70a5e1b
Edited by Medallion Man
