Front upper camber arms
HI an going be installing a set of front upper camber arms to my n/a z are there any inssues i should now about and any advice . ie how to install, will also be installing front sway bar poly bushes ..:detective:
If they're aftermarket arms then the longer side go to the rear of the car if that makes sense? As you look at them they ain't even.
That's how I've got them mounted but that's supposedly wrong. Jimmer reckons I should change them and he's usually right.
thats how they are fitted on just about every image etc that i can find.........fitted this way it surely gives more clearance around the spring??!!.Havent had any issues with mine being this way round.Heres another image that shows the longer portion facing towards the front.....
Edited by Rebel Scum
