oil
so i got my zed out today and noticed the psi on the oil was sitting just over 60 when cold which i think is normal,but when its up to temp and all is running well the needle is sitting just over the 0 and under the next line ,seems its a common fault and its to do with the oil sender or pressure switch anyone had this problem before
well thats good ,,so it is a common fault so how do i go about fixing it
where is it and where can i get one from?
If you ever get a sender unit not working , check the small oil input hole to see if it is blocked a lot of these units have been saved by drillng out the hole again with a small drill useing a small pin drill chuck.
can you point me in the right direction on the engine ,ive not had this problem before ,,,,,anyone got the part number of the part?
cheers mate will take alook ,,will it do the engine any harm if i dont get it done for a few months
no you can leave it like that forever lol!! a good oil change can sometimes work. it did for me :)
