April 18, 201214 yr Author ok being specific is there a z engeer within there traveling time that would visit the area of portsmouth
April 18, 201214 yr You have jimmer in bristol, thats about the closest. Ive tried locally and bad results. Whats up in any event?
April 18, 201214 yr Sorry, no. I've used Mototech in Milton, Portsmouth once. Nice enough guy but limited knowledge and experience of the Z.
April 18, 201214 yr is it coming from the box or the engine? lower rocker cover gasket leaks are very common. if its the box should pretty darn easy as its directly there when you are under the car. trans fluid is pink
April 18, 201214 yr Author think you are right will jet wash it asap and see where it reapears thanks
Hi
Got a transmission leak on my na anybody no anybody good?
