- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi guys,
I've just been to see a poorly Zed of a colleage of mine and need to bounce some ideas off you guys to see if I'm heading in the right direction.
These are the symptoms:
1. Car is very difficult to start
2. Idles EXTREMELY rough and stalls after a while (if you don't keep your foot on the accellerator)
3. ConZult ECU codes results - 13 (Coolant system) & 34 (Detonation sensor)
4. ConZult sensor reading - engine temp is very slow to climb to operating temp (took about 1/2 hour at 1500rpm to climb to 68C)
5. under light load (while stationary) there is obvious detonation (but not all the time)
The ECU code 34 is not a worry as (a)the connector is buggered and (b) the car is audibly detting.
I'm not sure what the matter is with the coolant sensory system as the actual temp sensor is new (no corrosion) and when disconnected it engages the aux fan. But it is very clearly giving the wrong signal to the ECU.
Another thing that the ConZult scan revealed was that the entire left bank of the car isn't firing (!) Plus intermittently, cylinder 1 isn't firing either (no wonder the car stalls)
My initial thoughts are that (a) there is a problem with the wiring loom and (b) the PTU could be buggered.
I will swap the PTU for a know good one and see what happens but I need some thoughts on any other causes of these problems. The car is pretty much undriveable and the problems manifested themselves over a period of two days.
Any thoughts are much appreciated.
Cheers!
Danny
