555 injectors
Hi all I'm after some 555's to push her to around the 400 mark what do people use? I've been looking at the rc's as that's what I have in the civic but what exact injectors do I need? High impedance, low impedance, side feed etc... Also what make do you guys recommend?
Nick
I've just bought some JECS 600cc side feeds. If you have an early car you will need the kit from Z1 so they fit the early fuel rail and change the connectors on the engine harness.
Yeah i have skyline ones in mine, there nismo 550's. you just need to make sure you have the right ones for the fuel rail. there are 2 types the early 89-93 then the later 94-99 iirc.
yeah there is a little metal clip to slide out 1st. can be fiddly. as jimmer said will be 95+ :)
