protoj ·
Hi guys borrowed a friends consult got these readings, how do they look to the experts
cmfs/rpm 712rpm
mas air/fl 1.28v
thrtl pos 0.46v
iacv-aac/v 24%
coolant temp 81 celcius
m/e f/c mnt= lean
battery 14.00v
vhcl speed 0 mph
o2 sensor - 0.22v
a/f alpha 99%
ign timing 15btdc
inj pulse 2.47 msec
inj duty 1.67%
any help appreciated thank you.
