350Z Brake Upgrade??
Quick question, Does anyone have the dimensions of the adaptors needed for the calipers when fitting 350Z discs?? Just i have a mate that runs an engineering shop so he can make the up for me, Sadly he is pretty busy so if i can give him the dimensions he can get them done for me quicker than if i take the car to him.
Cheers in advance.
No brackets needed for the fro.t you just have to drill the bolt hole out to the diameter of the 350z bolt size. Rears no bracket can be made.
if its 350 calipers as gibster said you just have to open the hub holes to 14mm . but if you are using 300 calipers you will need brackets . you might find some on ebay
I have a scrappy drawing for when I modded mine, can't post pics up from phone so will do it when I get home tonight for you :-)
I was meaning fitting 350z discs with the 300zx calipers, But i wasnt aware you could do the whole lot in 350z parts. Now thats interesting, as i believe when doing it the ther way the pad ends up with a lip on it due to not all of it covering the disc?
You are correct with your assumption, however in those cases the braking performance is still improved.
AlanZ has for sale the complete kit in the for sale section now, perhaps he or the new purchaser will allow to copy the brackets as they were never readily available "off the shelf" in the UK.
If you decide to fit the 350Z Brembo calipers, yup simply drilling a lug hole out an extra couple of mill does it, but be sure they are 350Z ones as R34 calipers which look the exact same and use the exact same size disc, are a different offsett.
Smithy
I can supply pics of the brackets b4 they are sold if you like.
Alz.
Alz.
If you could please, if you could measure the bracket aswell that would be awesome.
