effin z
got heater matrix hoses replaced today. then fired IT up and IT has now decided to be missing on a cylinder! i've checked around to see if i've snapped anything obvious,ie plugs to injectors etc.but all looks in intact. any suggestions?
cheers in advance ,lee
pull the connector off each coilpack and see if the engine note changes. Find which one it is then swap that coil pack with another to see if its the coil at fault or a plug?
Lso check the unjector plugs mate has it has the same syptoms as if a coil pack has failed ,As I had this on mine when I first got it
One of mine poped off with the vibration of the engine and it soulded like a subaru lol!!!
