Gents
As you know from my countless wanted thread I'm looking for a replacement clutch servo
I saw one on eBay for a y60 Nissan patrol
Does anyone know if it will fit or does anyone know if one from another Nissan will fit?
My clutch cylinder has got s13 stamped on it, so whether its the same as a 200sx im not sure but I think if you look on nissanparts.com you can cross reference part numbers :)
Now this sounds very promising can anyone else confirm if an s13 is the same if so i can finnaly get one
Its possible that the S13 Clutch master cylinder is the same as a 300zx NA Clutch master cylinder, but its definatly not the same as a Twin Turbo Master cylinder.
sure u dont have a Vac Leak on the piping to the clutch servo ...
as the clutch vac tank that sits in the wing is known for splitting
My clutch master cylinder with S13 stamped on it is fitted to a TwinTurbo and works fine.......and also worked on Hollowpoints old zed as that what my manual conversion was off
s13 s have a eye on the end where it attaches to the pedal with a pin same a na z32 where the 300zx tt has just a plunger which sits inside the servo.
Mines got a plunger........just seems a bit odd that mine has got s13 stamped on the end.....unless the actually aluminium body itself is the same between zeds and 200's etc just with a different piston etc fitted???
Its very unlikely that the S13 on the side of your master cylinder refers to the 200sx S13. Part model numbering doesn't tend to work like that.
Edited by Yowser
S13 Clutch Master Cylinder - 30610-04F60
Z32 NA Master cylinder - 30610-48P54
Z32 Twin Turbo Master cylinder 89-91 (vacuum servo assisted) - 30610-40P03
Z32 Twin Turbo Master cylinder 91 on (vacuum servo assisted) - 30610-45P10
I dont know the part number for the Y60, but googled an image and it has completely different fitment.
Edited by Yowser
It's deffinetly my clutch booster that has gone as when i suck directly from the booster I can't keep a vacum,
Trying to get s replacement is impossible
