injector plug wires
hey up folk! does anyone know where i can get some of the wire used to feed the injector plugs? the only stiff i can seem to find is way too thick. i could do with the same colours too really :-) cheers guys!
You guys know what size of wire the OEM wires are? think the live feed is a thicker gage?
Just one thing on this subject...I was told by a very reliable source that if you are replacing the injector wires/plugs you must disconnect the earth lead from the battery, or it can mess up the injectors. Sorry if you already know this! Good luck with your cable hunt.
hows that work then? so if you unplug the injector you should disconnect the neg lead?
No idea...I was told this so I thought I would pass on the info to be helpful.
Yeah is a good idea to unplug the battery when working on any part of the loom, especially the injectors as they are constant 12V+ anyways, anyone know the wire gages for the injectors??
Anyone know? I want to buy from here: http://www.vehicle-wiring-products.eu/VWP-onlinestore/cable/thinwall.php as they have all the oem colours available but not sure where to start with ensuring I get the right size!? Looking at my standard wiring is no help as I can't get a strand number match or measure to 0.1 of a mm. Anyone know the ampage rating of the injector wires?
S
and you were :-)
blimey, i never knew that. i probly would have blown something changing the plugs lol!
S
im looking for exactly the same pal, i shall let you know if i find out
  • 4 months later...
