caliper torque settings
does anybody know the correct torque settings for the 4 bolts that hold the two halfs of a brembo front caliper together . also the correct setting for the two bolts that hold the caliper to the hub . ive had a bit of a search around the brembo site but im not getting what i need . they are 350z alluminium calipers
cheers in advance
According to autodata
Brake caliper carrier to hub front 85nm
brake caliper carrier to hub rear 45nm
Service manual
Edited by groover
cheers graham for that mate . any info on the torque settings for the bolts that holds the two halfs of the caliper together , the ones labelled (do not remove ) .lol
You are not supposed to remove them :lol: I just did mine up fairly tight when i did mine, didnt use a torque wrench. Obviously you are worried because being ali, you dont want to strip the thread, M12 bolts (into ally) should be 34ft./lbs., M14 54ft./lbs
