One dead zed
The car has given up the ghost!
Came back last night from 140 mile drive and it cut out on the drive and would not start for 20 minutes, then quickly did the same.
Tried it after it cooled down and it started and ran fine. Checked everything that I could think of and all seemed OK.
Set off for work this morning, started fine, did three miles then loads of backfiring as the engine died. Spins over fine, just no go (absolutely nothing).
Any ideas?????
Mark, if you've got the old type PTU/ignition amplifier - whatever you want to call it then that's almost a certainty. You can repair it but you're better off replacing...
Cheers,
RobH
Oh bugger!
Where is the cheapest place to get one? Is this a call to the States? if so, are there any differences (this is a 92TT jap import).
Mark,
I just changed the PTU on my 91 NA. All versions of the 300ZX use the same PTU. The one from Courtesy Nissan is upgraded and does not look like the stock one on the top left of your engine. It comes with a mounting bracket and a cable adapter to
fit.
I was able to change it quickly and found that it was easier to screw the mounting adapter down first and then mount the PTU on top.
If you tell courtesy you are a member of twinturbo.net they give you a discount.
The PTU has a board that expands and breaks contact when hot. I understand that a good way to test is to pour water on the PTU when the car will not start. This will cool the PTU, if the engine starts then it was likely to be the PTU. But when mine went out, no amount of water would start the car.
[This message has been edited by BruceWard (edited 08-07-2002).]
one of the contacts inside breaks, pouring cold water over the PTU isnt really a definate test
I opened mine up & repaired it while i waited to get one from courtesy, $157 if i remember correctly
run it for a week with a new wire soldered in without any more problems. woulndt trust it as a permenant fix tho.
I feel the need, the need for speed!
Yeah Mark thet is exactly what mine did a few months back after a good hard thrashing.
Get it from Courtesy and save yourself a ton of cash on the £320 Nissan want here.
Mark if you order one tell me and we will order two and split import costs,mine is fine at the mo, but will go one day eek.gif
Cheers,
RobH
if you wanna try the old one of me z mate then ill send it you for nowt if you can give is a clue where it is/how to remove
i wont sell it cos you never know when itll pack up,it you might get lucky with it though
Just put a S/H one on that PaulG has loaned me to prove that it is the PTU and gives me a chance to get one ordered and stay on the road.
Burst into life first time and back to running like a dream (even when hot)
Respect to Paul, cheers m8
Ian, I'll give you a ring and get two sent across.
