protoj · Tuesday at 18:48 3 days
hey guys, im trying to fit a combined boost / rev counter. im pretty safe with the boost gauge side of it, (fit sender in to the place where it tees in. then wire through to the dash.)
but i dont know where to take the feed for the rpm? any ideas? cheers guys!
