Fuel filler flap
ok I'm having serious issues with my fuel filler flap for ages I have had a slight problem where I have to press the handle down once or twice recently however no matter how much I push down my flap won't open so at the moment I am having to drive with a lump hammer around in my car to put on the switch so I can get out and open the flap when I need to get some fuel has anyone else had this problem or does anyone know how to fix this problem? Cheers Phil
it might be something as simple as the thin metal rod that the flap hinges onto has ridden up or down. with the flap open make sure the hinge is seated correctly.
Edited by EvoluZion3
Yeah that was the cause of my petrol flap. Pushed the rod in to position and all worked fine
can i get away with a 'thats what she said' here?
i think so lol :yes:
and thanks guys i shall go have a look in a sec.
I did mine just the other day, the top right corner of the flap was just touching the body, i loosened the 2 phillips screws on the hinge bracket, tapped it to the left, then tightened them up, It's now dead square and opens a treat... Also, you may need to bend the spring out a little (metal strip in the middle of the hinge bracket)...
