steering u joint
any help
i need to get it out the way to make space for my new mani's
iv loosend the top bolt and removerd the lower one
how does it come off?does it slide up the platlic plate or some thing else
cheers guys
under the steering wheel fella theres 2 bolts holding the steering column in place remove these and you can pull the whole column into the car by a good way giving you enough room to get your manifolds on.
all the best
Craig
Not as far as i know, all you have to do though is drop of the lower panel under the steering wheel and you will find 2 10mm bolts facing down towards the floor, whip them off and away you go takes a few minutes
