engine revs!!!!!!!!!!
when first started the engine revs to about 2000rpm,Is this the norm?????Once warm it drops gradually to around 800without A/C,about 1000rpm with????
Mine goes to about 1600 to 1700 on start up but once warm it drops to 800 to 900 which is fine.
Matty.
when forst started cold ours runs at about 1600rpm for a short while, till it drops to bout 1100, when its up to temp it idles at about 750rpm. Ive been told to clean the throttle bodies though, as it will make it idle nicer, and just generally be nicer.
sig.x
mines the same and i have a dodgy coolant temp sensor, getting it fixed shortly though :O)
run an ECU diag and it will tell you if you have a prob with your sensors.
Mike
