Diagnostics cable connector
How many pins does your OBD plug have? Mine has space for 14 but only 8 are present, is that normal?
What's the small dial on the front of the ecu with the flat head screwdriver adjuster?
Can anyone help me out on this one please? Need to know if my loom has been modified or not, cheers
My cable has pins missing and 8 seems about right, without going outside to count them. I'm presuming you're talking about the one near the bonnet pull?
I believe the dial thing is to turn the ECU into diag mode. There should be an LED near it.
Yes mate thats about right
Pin
Number Pin
Name Description (may be empty)
1 RX (TX?) Data in
2 TX (RX?) Data out
4 ABS ABS diagnostic
6 CHK Check to ECCS
7 +12v Power
8 GND Ground
9 CLK Synchronization signal
The pot on the side of the ecu is set it into diagnostic mode and reading the flashes on the dash light
Check here
http://www.nicoclub.com/archives/nissan-300zx-z32-ecu-diagnostic.html
Nice one chaps thanks alot! That was the plug I was referring to was that one Dysan, i've always heard it referred to as a 14 pin so confused me when there were loads missing. Good link and site that Groover, cheers
