Driftworks Hicas Eliminator
I've got the DW Traction rods, Camber arms and Tension rods to go on and was going to order the DW Hicas elimination kit. I've been told that the toe rods that are supplied with the kit don't fir the Zed?! Has anyone else got the same setup and what did you do with the toe rods? Did you use an alternative arm or not?
Matt
Ive got this fitted with no probs whatso ever.
It comes with fat adjuster nuts and thin ones, you just have to remove the fat ones, fit the thin ones and then wind the adjustment all the way in, they fit perfectly.
Cheers guys! You've given me a better answer than the DW team lol. Time to order a new Hicas elimination kit :)
I had the same problem as Jon. But, I parted off 10mm from each end of both rods. That way, I could use the fat nuts and still have plenty of adjustment.
