ivor little un!!!
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
problem that is p**sing right off!!,When i drive off from cold early morning etc.The car has been stood all night i get a vibration between 20-60ish mph.Mainly under load, but you can feel it even when lifting off.I've had it since getting the car 6mths ago.It clears up a bit if you give it some stick(not from cold i like my engine).But drive for more than 30 mins or so and it seems to go away???What does anyone think?or have you had the same problem?? at first i thought it eas a miss fire but the engine run so sweet(not chipped???)propshaft was next i thought(nothing wrong here no run out probs etc.)but surely it would do it all the time if it was the prop??.So next i changed the diff oil it looked ok(no metal particals)no excesive play(car has done 90k).Drive shafts seem ok,not bent or twisted(a common prob with high hp cars),SO now has anybody got any idea's coz i'm getting annoyed(i'm thinking just change the f*****g lot gearbox ,prop,diff,shafts i'll cure the t**t)any thoughts ,help,idea's,parts would be...well...helpful! CHEERS!! P.S it does it in 2nd,3rd,4th,and 5th!! so i don't think it could be the box???changed oil,same again it looked ok.. ummmmmmm....that's about all i can tell you!!
