January 27, 201213 yr Got a oil temp gauge in my car and nearly all wired up except for the sensor unit itself. There appears to be a blanked off port next to the oil filter that would be ideal however it doesn't screw directly in. Who knows what size adapter I need? An ebay link to the required adapter would really help!
January 27, 201213 yr Author Would this fit/be a simple solution? http://www.ebay.co.uk/itm/Blue-Oil-Pressure-Sandwich-Plate-Gauge-Sender-Sencor-Adapter-Oil-Temp-Sensors-/320775456734?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4aafb507de
January 27, 201213 yr Author Or maybe this is what I need...? http://www.ebay.co.uk/itm/1-8-1-4-NPT-OIL-WATER-TEMP-TEMPERATURE-SENSOR-ADAPTER-P-N-12616-Silver-/330647433284?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4cfc1f7044
January 28, 201213 yr yes im trying to sort mine .i actual have a spare oil filter casing and have removed the little bolt.to me thatsthe ideal place to have the temp sender ,but others may differ.the thread size im not sure but will check.looks like you could use a ford temp sensor poss
January 29, 201213 yr Author Just ordered myself that sandwich plate adapter. Looks to be the simplest solution and can't see why it wouldn't fit.
