HKS triple plate clutch
Is anybody running one of these HKS triple plate clutches?
HKS GD Clutch Pro Multi-Plate Clutch Triple Plate Nissan 300ZX TT 90-96
Item #:
2604-RN027
Regular Price:
$2,100.00
Sale Price:
$1,889.00 You Save: $211.00 (10%)
A key component delivering engine power to the drivetrain is the clutch. On highly tuned vehicles the stock clutch quickly becomes obsolete because it does not have the friction material nor pressure to hold and transfer the additional power. Therefore a high performance clutch is needed to support and deliver all the engine power to the cars wheels. From using the T-002 and R33 DRAG GT-R to develop, test, and research the technology and dynamics of power transfer, HKS has created the HKS Twin and Triple Plate Clutch kits to surpass the demands of a high performance clutch. Twin Plate Clutch kits are designed for 700hp street use applications and the Triple Plate Clutches can handle over 1000HP, which are designed for drag racing applications.
The HKS multi-plate performance clutch kits are vehicle specific Pull-Type racing clutch applications designed for street-car use. The multiple plate design allows increased friction area and direct power transfer, thus offering greater horsepower and torque holding capacity and light clutch pedal pressure for easier clutch pedal management. The use of rivet-less clutch disks allow for better durability, increased friction area and direct torque transfer, while maintaining a friction material that is both wear and heat resistant. Each multi-plate clutch kit comes with a lightweight chrome-moly flywheel optimizes durability and high performance. The use of very durable and lightweight chrome-moly material with a steel tooth ring makes it possible to construct a thinner flywheel without sacrificing integrity. The concept behind a lightweight flywheel stems from the desire to enhance low-rpm throttle response on high RPM horsepower applications. With the lightened flywheel in the HKS Twin and Triple Plate Clutch kits, a quick rise in RPM can be attained from light throttle input for easier RPM matching when downshifting and to counter low torque at low RPM levels. Though the main focus of the HKS multi-plate clutch kits is on ultimate power transfer and engine response, a stable idle and smooth driveability is still maintained. Each HKS Twin and Triple Plate Clutch kit is a complete vehicle specific assembly that allows for a bolt-on installation. Some applications have an available slave cylinder rod that increases travel for enhanced pedal modulation.
Yes :)
How do you find it generally, is it quite clunky and heavy or pretty easy to live with
not really interested in how it launches but more so wear and tear, and slippage during clutch kicking etc?
also purchased in UK or imported mate?
I'm running a twin plate HKS
same questions as above mate?
cheers
One good thing is its hard to steal lol. Not very street and took awhile to get used to it. Like a switch with limited slippage. I quite like it now but it's an squired taste. If you google it the general feedback isn't good for street use :-). Bought in uk
As above but I find that it isn't too aggresive for daily driving, not fun in a traffic jam but certainly managable when you're used to it. Engagement is great, very easy to light up the rear wheels when pulling away, can be jerky at times if you don't give it enough revs etc.
I like mine.....came free with the car from Japan! lol only found it when I removed my old engine was like a christmas present lol
you've gotta' love surprises like that!
but for track use it's ideal then
Just following up on this
I'm ready to commit and press the 'buy' button but wanted to treble check that I'm going for the right option
if anybody has experience or prior knowledge of how the HKS triple plate, Ecedy triple plate and OS Giken triple plate compare then please comment
*please, in all seriouslness, only comment if you know what you are talking about
If I get this done now, it's looking good for the 26th at the Pod
