Somebody once told me how - but i've forgotten.
The idle on tickover gurgle & the goose honk on full boost, - i've drained the system (wiped the pipe off & let the condensation out) a couple of times now.
But one of you lot said at a meet 'bung a hole in the plastic box mate, sorted'.
Ok fair enough as it needs draining again.
Where should the hole be? how big? & whats inside the box anyway?
cheers, harve.
Simply drill a small hole at the lowest point where condensing water will collect so as to let it drip out. Bottom of the black plastic cover is the place I think. There's a how to on TT.net.
5 mm hole should be fine. Inside is an air filter basically.
The goose honk is nothing to do with the AIvs tho. Thats the recirculating valves - different things.
