Tyre pressures?
I can't find the PSI values for correctly inflated tyres on a TT - I've looked everywhere!
The sticker on the drivers door frame says "2.5 and 4.7" (I think) - I hope that's not PSI. Is it bar?
Ta.
J Spec (with 225 rears) or UK spec (with 245 rears)?
Clarkey sounds about right for J spec - will check in the am.
Cheers - Gio
It's in kg/cm2 2.3 front and 2.5 rear. I think the 4.7 is for the space saver spare.
33psi front and 36psi rear. At least for my J spec it is.
I'm running UK spec rims (225 front / 245 rear) on my J-spec Zed and keep my pressures at 33psi front and 34psi rear so as not to increase tyre wear in the middle of the tyre. Used to run 36psi at the rear but found excessive tyre wear down the middle (i.e., tyre was too "round").
Hope this helps,
Danny
