Could someone point me in the direction
of a how to do the mod on the dipp beam so it stays on when you put the main beam on as i have H.I.D's
thanks in advance
To do it properly, as per link, for a quick fix to stop the HIDs going off when you use high beam, just add a ground wire to one side of the ground on the plug to the HID bulb.
The only drawback with the quick fix is that your HID's will also come on when you flash someone.
