June 19, 200224 yr my power steering is erratic, sometimes hard to steer sometimes easy. the hicas codes are as follows: 1. one v long flash 2. four small flashes 3. one long flash 4. two small flashes 5. two long flashes 6. one v long flash please could anyone reply with the correct results, thanks yaz manchester (300zx tt jap)
June 19, 200224 yr 14 SPEED SENSOR CIRCUIT 11 CRANK ANGLE 12 AIR FLOW METER http://www.ttzd.com/izcctech.html FOR ECU DIAGNOSTIC PAGE ABOVE
June 19, 200224 yr Originally posted by yaz: my power steering is erratic, sometimes hard to steer sometimes easy. the hicas codes are as follows: 1. one v long flash 2. four small flashes 3. one long flash 4. two small flashes 5. two long flashes 6. one v long flash HICAS light codes for '90-'93: 1. HICAS solenoid R.H. 2. HICAS solenoid L.H. 3. Cut-off valve -x 4. Power Steering solenoid x- -x 5. Vehicle Speed sensor x- 6. Steering angle sensor 7. Steering Neutral positon sensor 8. A/T: Parking Brake Sensor M/T: Clutch sensor 9. A/T: Inhibitor sensor M/T: Neutral sensor is 4 and five the correct reading? thanks yaz manchester (300zx tt jap)
June 19, 200224 yr Originally posted by yaz: my power steering is erratic, sometimes hard to steer sometimes easy. the hicas codes are as follows: 1. one v long flash 2. four small flashes 3. one long flash 4. two small flashes 5. two long flashes 6. one v long flash HICAS light codes for '90-'93: 1. HICAS solenoid R.H. 2. HICAS solenoid L.H. 3. Cut-off valve -x 4. Power Steering solenoid x- -x 5. Vehicle Speed sensor x- 6. Steering angle sensor 7. Steering Neutral positon sensor 8. A/T: Parking Brake Sensor M/T: Clutch sensor 9. A/T: Inhibitor sensor M/T: Neutral sensor is 4 and 5 the correct reading? if it is what do i do next? thanks yaz manchester (300zx tt jap)
June 20, 200224 yr tried the hicas again this time i drove the car for a bit under 5 mph got a new reading: 1. one v long flash 2. seven small flashes 3. one long flash 4. one small flash 5. one long flash 6. one v long flash still cant work out what they are please could anyone reply with the correct results, thanks yaz good luck england 2-1 england wins manchester (300zx tt jap)
June 21, 200224 yr Mine did this and replacing the speed sensor fixed it. ------------------ "Polished on drive" "Dirty at 156mph" --------------- Z first and anything else is secondary and live life a quarter mile at a time! John Newcomb (NukeEm) www.geocities.com/jn300zxtt
1. one v long flash
3. one long flash
5. two long flashes
6. one v long flash
thanks
yaz
manchester
(300zx tt jap)
