led lights
Hi guys,
2x led problems lol,
The 1st is i have the lambo style lights on the rear but wanted to know if anyone knows where they just sell justthe actual lights as i have the panel allready seems most rear light conversions use the same lights, and i see a coach with them too.
The 2nd if i convert my dash to say blue leds, how do you go about changing the digital numbers on the air con pod too.
Any help appreciated,
Thank you.
Hi guys,
Thank you.
Talk to Groover on here, he is the LED specialist
Cheerz
Cheerz
Cheers mate i will pm groover now,
LED dash lights, unfortunately with lengthy talk with groover about the digital temp numbers, they are impossible to change unless you change the unit its self which displays the numbers, as i wanted to do that as well.
groover is your man as far as the rear lights are concerned though.
Hi mate, i have the fiat coupe lights, just wanna update to led and didnt want to have to buy a new panel,
Think i found some here, under rear lights.
http://www.s-v-c.co.uk/
They have loads of choices, got to work out what colour lol.
Looked at jasons car yesterday the beast, and we measured the panel and its the same size holes, he as the clear lights but on a dark car,
mine is white so was thinking red, jasons looked great when switched on, just 4x red rings.
Looks like i would need 98mm inserts.
It would work out a couple of hundred quid but better then nearly 500 from z centre when i have the panel anyway.
And it seems their E marked.
The fiat coupe lights i really use to like, but when you look from the side they seem to stick out from the recess with the led inserts they seem to fit flush and look a lot more modern when on.
Cheers for all your replys.
replace these..
With something like these, ....What do u think guys....
replace these..
Agreed.
replace these..
Same as mine bud, but i have 3 either side,,,,,,,, when its dark they look sooooooooooo awsoooooooome,,,,,, very bright
Cheerz
Chris
