The way not to make your TT faster...
  • Replies 35
  • Views 1.4k
Do you guys not get more lag than before fitting them?
More lag ?? the air is able to flow more freely with the larger cooler matey.
:ban:
lol, well its not exactly the easy way to do it, sure as shown you can MAKE it work, but you got to mess around with piping alot more.
I've been busy havn't even been online til now...
Yeah sure, but simple physics says more/longer/wider piping + larger cooler = more time to spool up to pressure and more time = lag. Happens a lot on GTS-Ts when people add front mounts (GTS-T has a SMIC as standard) and on GTRs when people uprate to a larger cooler and bigger piping, you get more lag, but smoother delivery etc. as someone else said here.
I'm not saying it SHOULD cause more lag, I'm asking if it does, because of my experiences with the RB engines. I am still yet to decide on a front mount or SMICs for my big build, so I'm curious :D
No more messing really, same as any fmic. You buy fmic with the pipework....or you buy it without and have the pipework made up separately....same either way.
You certainly dont get any fmic's that use completely stock pipework.
Edited by Yowser
I'm not going to sit here and say my initial post was saying they were totally useless and i should have worded it better... obviously it can be hooked up as has been shown. Of course you need different pipework regardless, but this seller doesn't include any pipework which would require going and getting it all bent up/ buying a set of pre bends and using silicon elbows.
The other option i posted is a complete set up. I really gotta lean to word things better on here it seems i imply things i don't intend and rile people up.
