Does anyone use the Godspeed turbochargers?
I want to know if they can be used with a stock ecu and injectors?
it's basically a chinese copy of the Jim wolf JWT600 turbochargers...which is more or less a t28 stuffed into the stock 300zx turbo housing, which is already a bad idea (imo) and on top of that, chinese turbochargers don't have a very good reputation.
It's not adviced to use this kind of turbos with stock injectors and ecu.
these turbos usually have wastegate actuators with stiffer springs and run higher boost.
I think the JWTs are a fairly popular upgrade for the Z. I spent a lot of time considering the JWT500 or 530.
...but whichever turbo you choose I'd have both a new EPROM and larger turbos!
Thank you for the advise and replies.
It helps a lot ;-)
