wats the difference
Is there any difference with a n/a or a TT steering rack??????
I have took off the rear steer and all the pipe work, i was going to change the steering rack cus of the pipes that com off for the rear steer. So i just want to no if a n/a rack is different with it not been a rear steer??
Edited by lees300zx
i dont think the front steering rack is much different, all the extra gubbins the extra impellor and lline on the pump the extra take offs on the pas pot etc are all related to the hicas. the front rack you simply have a high pressure feed and low pressure return. both about 10mm internal diameter, and a 22mm odd i/d main feed pipe from the res to the pump.
I will be gettin rid of the pump and the pot. So i can i keep the same rack???
