November 1, 201115 yr Who has had their prop balanced after fitting the manual half for the conversion, and how much did it cost? If you had vibration previously, did it cure it? Tudor...
November 1, 201115 yr I have a TT front prop and NA rear prop mine needs balancing as well hopefully should be all good i have taken the old balance weights off as well to give them a fresh shaft to balance
November 1, 201115 yr Author I've got a vibration from about 35 mph, centre bearing is fine, must be the prop I guess...
Tudor...
