Tyre size??
What the maximum size tyre i can fit on a 19" rim and 10" wide??
I have 265s on at the min and its stretched and i dont like stretched :turned:
well its for the rear, i think there 265 30 (or 35) 19R at the min.
Dont need to worry about the arch just like to know what i can fot on a 10" wide rim :)
Will that be flush with the rim do you know or will it give a little overhang if you know what i mean??
275 the correct size for 10" but you be ok with 295 no more tho
  • 4 months later...
bloody hell this thread is already quite old lol!!!
Do you have any pics. anyone else got any thoughts?
Take off all your wheels and stick 4 space savers on, then take it to a track...
It feels like that already with these tyres i have on. they send me flying when i touch a white line.
Yeah there just :xxx: tyres really dangerous and really stretched which i think is causing me my problems. there 265 on a 10" rim and before i had falken 452's on a 9.5" and 275 so the tyre wall was nice and flat and the back end was proper planted. I knew eveything the car was about to to.
With these ones i have on now ita impossible to tell when the back end is about to go and also since fitting these alloys the turn in on a bend and become really quick and the arse end is slow and feels totally wrong and the arse is about to go. Has to be the stupid stretch and tyre brand.
To get any traction from the rear the pressure is down to about 22psi. anymore and its impossible to drive. it hate it at the min.
just found out 265 is on the very limit that should be fitted to a 10" rim. In other words its really dangerous :(
it's more the brand, I run 265's on a 10.5 (at the front) and they're fine.
Im going for some Pzero's,
wow you must have some stretch!!!! I have the same crappy brand on the fronts but 245 and there fine because of the weight of the engine but the rears are just stupid.
They're not bad actually, R888 seem wider than other brands for the same size, and they have a stiff sidewall which helps.
Oh yes they look sweet. there look like they have a nice straight tyre wall. Mine go off at a 40 degree angle and the tyre is no where near the rim,
Hope the Pzeros will look ok. they have them on the R8 and ferraris from stock so the cannot be bad. measured my tyre and the 295 should give a nice flat edge i hope. got doubts no looking at yours they might belly over the rim to much??
Oh well we shall see :)
