Hi chaps,
I am nearing the end of an engine rebuild. I will be running an AEM EMS.
However, during the run in stage i thought it would be best to run a chipped ECU, then move onto the EMS when all is fine and dandy.
Is this necessary?
If so, i have another little query. The car was originally a manual NA. So i have a manual NA ECU. I also have a UK auto TT ECU.
The car will be a manual TT. If chipped, can i use either of these ECUs?
And finally, where can i get said chip? (bear in mind this will only be used for about 1k miles so i dont wanna pay silly bucks)
I can post spec if necessary
Yes, you can use any ECU (NA, TT, auto, man) in an NA TT car, as long as it's chipped
Also, for the record, you can use an NA ECU in a TT car, as long as you have a boost controller.
Cheers Andy,
Ok, i'm sorted for an ECU. Local video man can chip it. Any ideas where i can get a chip? Engine is fairly high spec.
You would have to list the spec of turbos and injectors mate and if cams are stock or upgraded, then you'll know your options for a chip
smithy
smithy
Bored block to pistons and honed and degreased
Checked block face
Checked guides and recut seats
Lapped and polished crank
Degreased and cleaned water ways
Skimmed heads
ACL race rod and main bearings
Z1 engine rebuild kit
Z1 120k service kit
HKS GT2510 turbos
Z1 Oil feed lines
Z1 RFL BOVs
Z1 side mount intercoolers - chromed intercooler piping
Stainless steel Intake hard pipe kit
Z1 upgraded throttle bodies
N/A oil squirters
AMS exhaust manifolds
Wiseco pistons 88m
Cometic 89mm head gaskets 0.51 thickness
Plate crank front/rear spacer
Nismo thermostat
JWT Mild 100 series cams
JWT VTC springs
New water pump
New oil pump
New water temp gauge and ECU sensor
ARP head/main bolt kit
Timing belt idler pullleys
Crank sproket
Z1 silicone PCV kit
AMS light weight full pulley set
Stainless Steel braided fuel line
AMS radiator
Full Custom stainless exhaust
NGK spark plugs
AEM EMS with 3.5 bar map
Greddy profec b spec II boost controller
Greddy radiator cap
Plenum bypass
Z1 full flow oil cooler upgrade kit
Z1 split 5 stud down pipes
z1 new style dual intake with apexi filters
AIV bypass
CC bypass
PRVR bypass
EGR bypass
Power enterprise Magpower II oil filter
Z1 full silicone pipe set
Stainless steel IAA valve feed pipe
Silicone vacuum hoses
Greddy extreme timing belt
Nismo 555 injectors
Drive chain
NA manual gearbox
Stainless steel clutch line
Nismo transmission mount
Z1 one piece prop
Z1 6 puc performance clutch
Z1 lightened fly
Lol ok, it's only the turbo's, injectors that have much impact and as the cams are stage 1, see no reason why a normal 555cc chip won't do the job for you for running in and until you fit the AEM fella.
Can be supplied by John Dixon, AndyP ( i think) or Zedworld.
Cost for the chip should really be a 100 bucks or less and of course you can then sell it when not being used any more, sometimes they come up for sale second hand.
smithy
Once you cut through the stuff that has no effect on engine performance it has not got a huge list of actual engine mods just bolt ons so prolly could be run on a stock ecu chipped probaly with a custom map.Id have gone for high flow exhaust manifolds and ditched the cams personally on that build.They can be added at a later date.
It has AMS manifolds. Cams are just mild.
Yeah, I gathered a lot of that stuff would be irrelevant, I just copied it from my wee car folder :)
Ahh yeh i see now the manifolds.Get the heads ported.makes a massive difference with bigger tubs too.Helps to get them spooling lower down the rev range.You could still permenantly run that on a custom mapped stock ecu if you wished though.
Really? Would the AEM not be better for simply fine tuning the engine?
Also it has dual intake. I intended using an AEM map sensor and ditching the MAF?
Oh, heads have been ported.
A standalone system will always be better but if you wanted a q45 maf would run that or a doolz set up on a chipped ecu.If you have the AEM already then your committed really.If you dont then consider either a custom map or an Emerald system perhaps?
