I am currently upto getting the timimg belt on and need some advice.
On the lower crank there is a dot, but where on the engine should this line up to?. Is it the little cut out mark on the oil pump thats at the bottom right hand side?.
Thankyou.
Check out the FAQ jeff did a writeup on aligning the timing belt its under how to,s
Jim
Thankyou :-). 2hrs i wa pondering and it turned out to be the mark i thought,lol.
5mins later and the timing belt is all good and fitted :-).
Its quite easy when you see it explained in pictures
God bless Jeff
God bless Jeff
Sure is.
Just need to remember where all the brackets for p/s pump and alternator go now.
It was nearly 4yrs ago when i took it all apart :-(.
Rather you than me , its hard enough remembering what bolts i slackened just toget the belts off a fortnight ago:oops:
Sure is.
Good job it was only 4 years ago and not 4.5 or 5 years as you would never of remembered sign0095.gif
I don't get it? lol
LOL...i think it was sarcasm... most people couldn't remember if they did it a week ago....
but I think the original comment had a touch of sarcasm to it anyway...
anyway... it's really not important... :)
Oh I get it, ok so note to self, sarcasm doesn't register before 10am on Sundays :(
