battery tray removal
How do i remove the battery tray. As the person who owned the car before me as let acid keep dripping from battery and its rotted the underneath and inner wing thanks
I drilled out a few spot welds and then used a hammer and chisel to pry it off. Probably not the best way to do it but it worked.
Wow, access to that passenger side turbo is massively improved! Shame theres no mod that improve drivers side access too!
i have removed mine too.
spot weld drill is the neatest way.
i should have similar access on the other side as i have removed all the gubbins over there too
Its worth checking the other side too mate early models leaked brake fluid over the inner wing
