high idle
hi all just a quicky prob done something silly, i fitted a new tps (i have an auto and the gear change was sloppy) it fixed the gear change but now the car idles at about 1700-2k rpm i set the tps at .47v at closed throttle is this correct?
cheers again for the help
nick
Try restting the closed throttle memory settings, with the engine running or just ignition on, unplug the large one going into the tps at the side wait around 30 seconds and then plug back in...should do the trick.
Jeff TT
