Brembo Brakes.
got me Brembo's think originally off R33, but once i started to clean them up came across some problems so thought ask all the questions before i go any further.
1. As you can see from the pics the dust seals are cracked/split so where can i get a seal kit to service them and is there a how to so i can do it myself?
2. The front brake disc's look pretty shot and i think i read the minimum thickness for changing them is 28mm both are around 24.46mm! so i need a pair of fronts which i think are 324x30x54? the rears are around 20.73mm dont know what they should be!
They bolted straight off a Z without any adaptors so pretty straight forward to put back on, i am going to paint them and from reading old posts Hammerite does the job and with some decals should be good as new.
dan.:biggrin:
Edited by dannzx
  • Replies 31
  • Views 1.8k
They look fantastic matey......... Will stop the zed on a "sixpence". Looking forward to the fitted pictures Dan.
I am finally getting my brembo set up fitted Monday......... I cannot wait!!
Alz.
Alz.
You give up on the 350z brake conversion then mate,im on my third set of discs now !!
I am Jim.........
The 350z is a great set up, but I got some Evo VIII brembo calipers ready to fit this Monday............. Can't wait!!
Alz.
Alz.
thanks, look forward to some pics once you have them fitted :thumbup:
dan.:biggrin:
Hi,
Awesome looking brakes after all your work.
Ive got a set i need to sort out, but just the fronts. (Do you need the backs or just a matching set?)
Can i ask who you used for the refurb of the pistons/sills ect and the fantastic powder coating?
That red is spot on, and did they do the decals as well?
One last qs, i want to get braided hoses, so id go for standard 300 ones on the rear as staying stock, but what hoses on the fronts, 300 or GTR?
Thanks for your help
Matt
Hi,
Matt
thanks, i stripped the brakes down and prepped them and a mate powercoated them for me then i did the refurb, the decalls i got off ebay just sent the size i wanted,i got braided brake lines all round with the standard Z brakes so they do fine.
dan.:thumbup1:
