Hi
I have a small problem. I've installed plasma gauges and managed to damage the Kph speedo when removing the dial. So I had do use one with Mph... Is there a converter that I can buy or somehow calibrate the speedo ??
Did you take the needle off completely? i might have a spare kph speedo if it will help.
The other option would be to change the resistor on the speedo board for it to read in kph and there are 2 variable resistor pots on the board also which can be used to calibrate, there is a write up somewhere to do that, i will dig it out and post it up here for you.
Had to remove the needle to get the plasma dial on.
If possible i'll try to change the resistor, so would appriciate the write up if you find it :)
