protoj · Tuesday at 18:48 1 day
When one turns on the lights (side or heads) the Air Con display, clock backlight and some other stuff dims! I want to turn this feature off, or add a switch - anyone have any ideas - before I start burying my head in the Zeds circuit diagrams???
